How can I set keyboard to caps lock?
doron
Apr 17, 2007
1,141
tampa, FL
is there anyway to type in all caps I thought there was a way to lock all caps down
garretwp
Sep 3, 2007
125
After you enable caps lock from the settings menu, you will need to do a double tap on the shift key to enable the caps lock.
- Garrett
Chris716
Nov 29, 2007
807
IL
thanks that works.. ive been trying to figure that out...
