How come I keep getting this error
B-Rad
Jan 5, 2008
22
Brownsville, TX
I have the Installer app on my iPhone but when I try to install anything it gives me this error message
"Main script execution failed"
B-Rad
Jan 5, 2008
22
Brownsville, TX
I did another jailbreak using ZiPhone and it works now, how do I go about getting ROMs for NES into my iPhone?
GADeputy
Jan 21, 2008
381
Georgia, USA
Power off your iPhone for a few seconds and then turn it back on. Now go back into Installer and try it again. Works for me.
S
Starry
Guest
That pic makes my face hurt... OUCH.. :(
CBRfanatic
Feb 28, 2008
302
Bronx
Ok, have you;
1. Installed so many 3rd party apps that you got the disk space warning?
-YES-Did you install from the Orange source the disk space fix?
-YES-It screws up permissions. There are ways to fix it, i just jot down my source list urls, restore through iTunes to 1.1.4, jailbrake with ziPhone. put my sources into installer, go through my list and get back what i had, MINUSthe disk space fix from the orange source.
Your going to have to change disk allocation limitation via terminal.
If you didn't install the fix from the orange source, then you installed something that messed with the directory of where 3rd party apps are installed. If you try to uninstall something and you get the same error, then bingo, this is what you did.
B-Rad
Jan 5, 2008
22
Brownsville, TX
I have every thing working I just don't know how to get the ROMs in the NES emulator with Mac, How would I do this?
CBRfanatic
Feb 28, 2008
302
Bronx
did you restore everything, or did you just run ziPhone on you jailbroken iPhone again?
i sent you a pm on the roms.
other then what i pm'ed you about, youll have to use ssh or ftp
B-Rad
Jan 5, 2008
22
Brownsville, TX
Do I have to install other things from the installer to do this? Like the BSD Subsystem or the OpenSSH Do I have to create a folder on my computer?, if so where? I have the ROMS I just don't know how to get them on the iPhone
CBRfanatic
Feb 28, 2008
302
Bronx
your going to need both.
Then Check out THIS website for a short and sweet run down.
B-Rad
Jan 5, 2008
22
Brownsville, TX
I followed the instructions up to the Terminal part is there a program you can use on mac that would make it easier that code writing everything?
CBRfanatic
Feb 28, 2008
302
Bronx
Try a program called Fugu
Its a mac FTP, SSH, SFTP, etc program
