How do I "Access" my 1.1.1 iPhone?
Azteka
Jul 10, 2007
64
The 707
I finally updated to 1.1.1, now im trying to put ROMS and RINGTONES on my iPhone, how can I access my iPhone's Directories on my PC? (kinda like what iBricker did) what programs do i need and how do i do this process? Thanks!:cool:
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Are you Jailbroken? More info please
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
If your on a windows machine the easiest program I have found is one called iPhoneBrowser. It opens the phone like Windows Explorer does your computer and allows you to drag and drop software onto the phone. There are several other options but I have found this to be the easiest. iBrickr also works for copying files onto the phone but I had some problems on a jailbroken 1.1.2 installing software off iBrickr. Copying files works great but I would stick to using Installer to put actual software packages on the phone.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Also do not leave ssh on because it will drain the battery fast.
