How do i add a theme from my computer?
Heller
Sep 27, 2007
34
I like a lot of the themes from modmyiPhone.com however, some of them are not on the installer.app
so for instance, if i wanted to add this theme,
http://www.modmyi.com/forums/downloads.php?do=file&id=849
how do i install it? just download and install with ibrickr?
also, say if i wanted this battery image,
http://www.modmyi.com/forums/downloads.php?do=file&id=144
how do i install that?
also one more question, :sick:
how would i install custom icons?
http://www.modmyi.com/forums/downloads.php?do=cat&id=18
to anybody that can help, i'd be great full :)
I install everything via SSH. Use a program like CyberDuck to get SSH access to your iPhone. Then you can install things. For instance, to install a theme, I believe you go to to var/root/Library/SummerBoard/Themes, or something like that, and drop the theme into the Themes folder.
patrick_83
Oct 11, 2007
310
Illinois
Or if you are a PC user you would use WinSCP instead of CyberDuck.
Heller
Sep 27, 2007
34
can i use ibrickr instead of winscp? ibrickr is a little more "easier" for me to understand...
thanks to both of you guys thus far :laugh2:
buttsecks
Oct 1, 2007
i have winscp but im not sure how to use this to get a theme onto my phone. any help?
patrick_83
Oct 11, 2007
310
Illinois
1st you will need OpenSSH installed through installer
2nd have an active WiFi connection to your phone
3rd get the phone's ip address
4th open WinSCP enter the IP where is says Host don't change the port enter root as the username and dottie as the PW (some ppl have said alpine for the PW)
5th hit login on WinSCP
6th locate the directory you want to put the modded file into
7th if you are using customize you can find that directory at
var/root/Library/Customize
or for summerboard its
var/root/Library/Summerboard/Themes
8th if you don't have those apps then you have to replace the default files yourself which is at
System/Library/CoreServices/SpringBoad.app
you might have to follow any readme that came with the file/s aswell
I think that is it hope that helps
Zackram
Oct 5, 2007
Actually you can use iBrickr to install themes, just go to /var/root/library/summerboard/themes/ and there in the themes folder create another folder with the name of the theme you want to add, next, in the folder you created paste the dock image that the zip of the theme has and right there in that folder create another that is named ICONS and inside that one paste all of the icons that the zip file has in order to be able to use them in the springboard.
Hope this helps! :cool:
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
iBrickr would be a little easier, but I don't think you can use it yet with 1.1.1. I've been using winscp with no problem.
~mike~
Aug 24, 2007
Ok i used the username and password as told but it would not open..Please help...Thanks
papabro
Jul 23, 2007
101
MA
The password with firmware 1.0.2 is dottie. The password with firmware 1.1.1 is alpine.
