How do I block unknown phone calls?
Webby
Jun 5, 2008
96
Someone keeps calling me "unknown" and it is driving me nuts! I don't want this person calling me anymore. Is there an app to block unknown calls? please help.:mad:
6,682
I called AT&T and had a block put on my phone that will not accept calls that are blocked or unknown.
I called and explained that I was receiving quite a few of them and I wanted it to stop. They had to check on something, but were able to put a block on any call that didn't show it's number.
Sharunda
Jun 16, 2008
4,987
1,085
One Horse Town, New Jersey
Hi Hawk: I've been having this problem too and I called AT&T and they said they had no block for these calls. I called again and told them that someone I know (although I actually don't "know" you) has an iPhone and has this same problem and got a block from AT&T for these calls on his iPhone. They did the research and insisted there was nothing only for the land lines.
So can you get the exact name of the feature that was put on your phone to block these calls? AT&T insists there is no such thing.
I appreciate your help. These calls are madenng.
6,682
hmmm... I don't know what to tell you. maybe it was called something different, or the circumstances were listed differently. I was mostly complaining about telemarketing calls at the time and that's what I was trying to block, but only the ones that were blocking their number. It just happens that it covers just about all blocked calls.
I can tell you that I don't remember having one since, and the company that was calling with the blocked number switched to a known number(s).
Sharunda
Jun 16, 2008
4,987
1,085
Hi Hawk. I took another crack at it and I told them that it was unknown telemarketer numbers and they still insist they have nothing that can block calls. They say they do not have this feature for any cell phones. I again told the rep I know of someone who had had this block put on their cell phone. They can only block up to 10 numbers I think that's the amount she said and that is if you know the phone numbers.
Hawk can you please call AT&T and ask them what features you have on your phone. If none of them sound like a blocking feature can you ask them about the blocking you have because a friend of yours needs the same thing.
styfle
Mar 31, 2008
3,381
This works really well: http://www.trapcall.com/
Its not an app but it unblocks blocked numbers. My home number always comes up as blocked an I used this service and it unblocked it.
There was also no way the caller could know the number was being unblocked
Quake97
Jul 10, 2007
522
Philly Burbs
I second the recommendation for trapcall. It works great and doesn't involve a lot of tinkering. When you get an unknown or blocked call, you decline it, wait a few seconds and the phone rings again showing you the phone number. Very cool.
Joe
P.S. Trapcall is from the makers of Spoofcard.
Oct 29, 2010
thats easy! go to texting and for the name of the person, type in, 8888. then, in the message part, type in: " b: (then type in, 'unknown' or, download the mr.call app, and block private calls
Locutus
Aug 22, 2010
98
24
So does anyone have a solution that doesn't involve jailbreaking one's iPhone 4?
I have telemarketer from India that will not stop calling me. They use to call me with a number that showed up in caller ID. Now they call me with an unknown number.
Beemer
Jan 24, 2010
284
Calgary AB, Scottsdale, AZ
I can't help your immediate problem but I will tell you what I do so you don't have this issue in the future.
I got a google voice number and have it forwarded to my cell phone. I only give my cell number to people I know. If someone needs a number and I don't know them or trust them (department stores, services guys, ect.), I give them my google number. Using google voice, it is very easy to block numbers that are unknown or even if you know the number, you can block it from coming through to your cell. I have done this since google voice came out and it works great.
MrMike6by9
Nov 16, 2008
1,482
120
69
Maryland, USA
Until you get to substitute your GV number for the native mobile number, you can create a contact called "Annoying Caller" (for example), assign a silent ring tone to that contact and then add each such number to that contact. It doesn't block the call but it keeps the phone from ringing out loud.
Good luck.
6,682
lol! I just used the voice recorder to record 30 seconds of silence. renamed the file to silent ringtone.m4r and assigned it to a couple annoying callers.
