How do I change stuff like battery icon
mutilate607
Jun 29, 2007
80
ok i got ibrickr and everything but im wondering how do i change the other stuff like the color of the battery icon and carrier logo and stuff like that can somebody post me a little walkthrough/guide. i use ibrickr
spampy22
Jun 8, 2007
165
45
Columbus, Ohio
Use a program called Customize and you will be able to change evertything you are asking for. If it is not showing up under applications in iBrickr then install the Installer app and look through there.
Do a search for customize and see more info
mutilate607
Jun 29, 2007
80
o ok cool its in ibrickr like how do i add new images to it?
mutilate607
Jun 29, 2007
80
what? where do i get new themes n stuff for liek summerboard/customize and how do i put them in?
