How do I change the position of my favorites?
Alkali
Nov 1, 2010
243
Nigeria
Hi members,
I have upgraded to 9.1. Wanted to edit my favorites by moving some up the line but no matter how I try it's not happening. Restarted the phone but still. Please help.
Alkali.
47seijar
Oct 6, 2012
342
126
43
Denville, NJ
Are you trying to move the apps on your home screen? To move apps you hold your finger on one until they all start "dancing." At that point you can tap and hold on any app icon and move it on the screen. When you're done you simply hit the Home button on the bottom of the front of the phone to stop the dancing.
Alkali
Nov 1, 2010
243
Nigeria
No, in the old days when you open phone app you have your favorite contacts, when you select EDIT you can move then up or down defending on the one you want but in my case there is an option to press and hold a contract to move up or down but nothing happens. You cannot change their position.
Alkali.
28,365
5,506
Rather than trying to move the icons, go to Safari > Bookmarks > Favorites > Edit > and rearrange the order. Whichever one you move to the top of the list will be the first icon and the bottom one will be the last icon.
Alkali
Nov 1, 2010
243
Nigeria
Thanks Europa I have found a way. There is a slight change on how you press and move the favorites and have done it. Thanks very much.
Zanthe
#apple
Aug 9, 2007
2,630
314
He's talking about "contacts"...
...or maybe not. O_o
B89rent89
Sep 19, 2012
170
17
Yes,3D Touch is buggy with this. With only 2 favorites the top one easily moves down to become the bottom one but the bottom one won't always move up to become the top one. With several favorites I have one somewhat in the middle that won't move at all.
B89rent89
Sep 19, 2012
170
17
On second thought it appears to be a "speed" thing. After clicking EDIT-button if you click the move bars( triple bars to the right of contact name ) and move up or down instantly you'll have no trouble. If you delay only slightly, 3D Touch engages and brings up a menu for calling, texting face timing or whatever depending on how contact is set up. Bottom line go FAST!
Alkali
Nov 1, 2010
243
Nigeria
Just tried it! When you pressed the move bars,you have to hold it with little strength and then move. It will work.
Ledsteplin
Oct 29, 2013
4,824
987
65
Florence, AL
You don't really need to "press" to move the Favorites. Just lightly touch the move bars and drag. Putting pressure down on them will activate 3D Touch.
