How do I clear theme update from Cydia?
EverythingApple
Jul 28, 2010
3,867
223
North Jersey
Genesis has an update, but I don't want to update since I already themed Genesis the way I wanted to. I'm assuming my thinking is correct? So, how do I clear the Genesis notification of an available update? Do I rename the theme? If so, how do I fo that? Thanks in advance.
EverythingApple
Jul 28, 2010
3,867
223
North Jersey
I found my answer. I tried changing thename but it didn't work. So, I selected "Change Package Settings" from the Theme page in Cydia and selected/turned on "Ignore Upgrades." I should've looked before posting but maybe someone else has the same question and I can help. :)
iphonewarrior
13,847
699
Another way to do is to use iFile. Navigate to the themes folder on your phone, copy the theme i.e Genesis and paste it in to another folder. Rename the folder Custom or something of your choice... launch Cydia and update.
