How do I conect my iPhone to my AOL home WiFi?
Philmac
Jan 19, 2012
Hi anyone help me and get my I phone s connect to my aol home router. Wi fi is on and finds me but won't connect. Do I need to adjust anything or put anything. In any of those boxes marked Ip address router. URL domain and so on. My laptop connects fine. My I phone finds it but that annoying circle thing just spins round and round. Philip mcl@aol.com any help appreciated thx
rambo47
Apr 4, 2010
528
79
Northern NJ
Your iPhone should connect automatically. You might have to enter the network WEP key if you've protected your home WiFi network. In Settings > WiFi you should be on DHCP. The prompt for entering the WEP key should be automatic. If you're having trouble you can click the button for Renew Lease and it should force a re-connection. You might also try unplugging your router for a minute or two and then letting it reboot. Often restarting a router it all that 's needed to sort out connection issues.
