How do I copy contacts from a Samsung Galaxy S5 to iPhone?
bdukes2962
Jan 14, 2015
Is there are easy way to copy contacts from Samsung S5 to an iPhone 6? Thank you!
Our company issued us new phones, but is not providing us with technical support so we can adjust to the new one. They probably thought that everyone is tech savvy … poor me
radtechy
Jul 20, 2011
505
41
Get them to you're gmail account export them to a contact file I think it's a csv format then save it to you're computer then go on to icloud.com on a web browser and import the csv file.
I did it this way for my wife and I when we converted from Google contacts/calendars to icloud
Good luck. This should do the trick
  • Like
Reactions: Rafagon
coop1701
Jun 30, 2007
899
114
43
If you had a gmail account you were syncing your contacts to on the samsung. Yes you can. Just add that gmail account under Mail, Contact and Calendars. When it asks about Contacts.. Answer Yes. I think you could also export them all from your web browser, saving them as a file.. Then using your iCloud Address book, upload that file. Either way should work.
Jad
Mar 1, 2015
Sync them with Outlook on pc using Samsung Kies 3 for the galaxy s5 and iTunes for the iPhone
tylorlundr
Mar 20, 2015
If you had a gmail account you were syncing your contacts from samsung to iPhone. Yes you can. Just add that gmail account under Mail, Contact and Calendars. When it asks about Contacts.. Answer Yes. I think you could also export them all from your web browser, saving them as a file.. Then using your iCloud Address book, upload that file. Either way should work.
I also use Gmail account to transfer contacts from my Samsung Galaxy Note 4 to new iPhone. It indeed convenient.
  • Like
Reactions: coop1701
ujkahefa
May 3, 2017
Below are main steps that takes place in this contact transfer process. For their complete details go to Samsung S5 Manual-
Step 1: Launch Samsung Galaxy to iPhone Transfer tool, connect your devices to PC
Step 2: Select Contacts to Transfer
Step 3: Start transfer files from Samsung Galaxy to iPhone 6 Transfer.
Tankssfea
Aug 23, 2017
Why not learn to attach a link, this will be more detailed about Samsung to iPhone transfer ,
LiuLiuQiu
Jan 4, 2018
You can use phone transfer, which is a professional software to trasnfer contacts, call logs, text messages, photos, videos, musics, calendar and apps between Android and iOS devices by one click.
