How do I create a new mailbox on iPad?
Bronsgran
Jan 15, 2011
14
I have followed the instructions to make a new mailbox with no success.
Instructions say to tap edit but I don't have an edit to make a new mailbox help please
Sent from my iPad using iCafe app
iphonewarrior
13,847
699
Do you mean add another email account to your iPad?
Bronsgran
Jan 15, 2011
14
Don't know if I replied or where it went if it did
I mean that all I have is inbox sent and trash and want to make a new one for storing
I have pop3 account by the way
RoofMonkey
Jun 21, 2010
8,924
1,984
You won't be able to add folders since its a Pop3 account. Needs to be set up as an Imap account. Check your providers website for info on how to set your mail account up as imap, if they allow it.
  • Like
Reactions: Bronsgran
Lon
Jun 5, 2010
2,946
132
Alaska
If you have an imap account on your iPad (like gmail) you can set up a new folder in that account and store your pop3 account emails there.
  • Like
Bronsgran
Jan 15, 2011
14
That is all very helpful thank you
I will try wi imap
Does that mean I should delete the email accounts and start again
patrickj
Sep 2, 2007
6,221
407
Austin, Tx
ipadinsight.com
I will try wi imap
If you have only just begun with the POP3 account, and have nothing important in it, deleting it from your iPad accounts might be helpful - just to keep things cleaner.
Gmail is a good, free option for an IMAP account. It will definitely allow you to create folders (called Labels in Gmail). One of the biggest advantages of an IMAP account is that it keeps things in sync between the email server and client very nicely across desktop PC, iPad, iPhone etc. POP 3 accounts don't have that capability.
If you don't already have a Gmail account, I'd suggest creating one in the browser on your desktop PC. The setup on iPad is very easy and quick once you have an account.
