How Do I Delete Ipong And Other Apps ?
southmade
Jun 29, 2007
44
ok i have demoapp and field test on my main screen
do i need these?
can i just go through my files in ibrikr and delte every single file in the demoapp folder ?
i hate just havign two ? mark icons on my main iphoen screen !
stuart9682
May 29, 2007
116
use Installer to install rSBT. now use rSBT to put those icons and any others you might prefer under the 'Hidden' section. Now they should be gone from your main screen.
akophone
Aug 1, 2007
300
For the iPong and other 3rd party apps, tap Installer, select Uninstall and select the app you want removed. Done!
southmade
Jun 29, 2007
44
ok field test and demo app are not in my uninstall ?
and both have ? marks for the icon ?
what are these and how do i delte them and is it safe to deelte them ?
Casetay
Jul 29, 2007
45
I am also having a problem deleting an app I put on manually not using Installer. It's like iPhone remote and it has a question mark for the icon but it won't let me delete it using Fugu...I'm on a mac too
