How do I delete songs from my iPhone?
11
im noob so here we go. im just wondering how i delete songs off the iPhone. i go to iTunes and under My iPhone than music.. i see all the songs but their all faded kind of. and im not able to click them or delete them some how. is there a setting i should be noticed about? thanks
Dec 29, 2007
I got some pics on there I don't want others to see lol of my girl. Is their a way i can delete them?
iCafe
Dec 11, 2007
1,877
www.wwtdd.com
Hello sir it is evident you have pictures of females in various states of undress , you can either delete them from your iTunes library and then sync or you can open the photo app on your iPhone click the picture go to the trashcan on the lower right side and click delete.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
You can download them off the iPhone to save and then delete.
If you just want to delete directly from the phone go to the picture, and the trash can is on the right side.
gregneedham
Jul 9, 2007
59
The safest way would be to send them to me for careful archiving, then delete from your phone.
termleech
Sep 7, 2007
1,154
McPherson, KS
Sure, thing, you can sync them with your computer using iPhoto and delete the originals when it asks, then upload the photos on EIC and delete them from your computer :)
j/k
Jan 13, 2009
how do i delete songs from my iPhone
Or simply go to iTunes to your music library and find the song in the list and uncheck it. Then when you sync, the song will be removed from your iPhone.
i think i am missing something, i need to go uncheck 1,500 songs and then resync my phone?! then, do i need to recheck them in order for them to play on my computer?
my phone synced all my songs the last time i charged it and now there is no room on my phone.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
SikShift is right. If you don't want those on your phone any longer, uncheck the particular songs you want removed. You must also be sure to check the option "Only sync checked songs and media". You can highlight multiple songs at once and choose to either "Check or Uncheck selection" to make it a bit easier.
Ace2009
Jan 12, 2009
This is through iTunes, right?
Mike12000
Oct 22, 2007
116
Southern Illinois
I've always managed all of my iPhone songs through various playlists. One playlist I sync has about 900 songs. I can delete entire playlists with one click from the iPhone main menu screen on my PC or I can go into individual playlists and delete songs or blocks of songs from there.
Sounds like you issue may stem from the songs being "grayed out". I've never seen that. On a PC I can highlight a song, Shift and left click at the bottom of the group I want to delete and remove songs as a group that way on iTunes, from a playlist I wish to modify for the iPhone.
I dunno, hope that's some help...
frenchst
Jan 9, 2010
thousands of my photos had been uploaded from my computer when I synched. iPhones help was no help. so redid the synch using manual selection of which files on the computer to synch, pressed apply and waited for it to snch again. magically it removed all the previously uploaded photos from my iPhone. there must be a better way than this
aniatara
Feb 17, 2010
I want to delete songs from the iPod on my iPhone. I went to iTunes on my Mac and deleted them there and synced the iPhone again but the songs are still there. Then I rebooted the phone and they still are there. I hate them! How do I get them off once they are no longer in iTunes on my computer?
