How Do I disable Low Power Mode When It Gets Stuck?
Jul 3, 2016
New Jersey
Low Power Mode reduces battery consumption until you are able to fully charge your phone. I often find that while in this mode my phone screen freezes and I have to restart the system. Did anyone else face this issue? What did you do to fix it?
Avery Eisenreich
Ledsteplin
Oct 29, 2013
4,824
987
65
Florence, AL
I don't use it much. It mostly just disables things I use. And it shortens the autolock to 30 seconds. I don't like that. But the few times I have used it, nothing froze up. I've heard no complaints about that across the forums I visit.
If it continues, you may want to restore your device as new, not from a back up.
28,365
5,506
Avery Eisenreich
This sounds like a glitch. Try doing a hard reset. Press both buttons at the same time until you see the Apple logo. If it continues after this, reset your settings through the Settings app. If that doesn't fix it, a restore will.
