How do I get my iPad onto the iTunes on my laptop?
May 14, 2013
I ve just spent an afternoon following instructions on how to download my old DVD s onto the ipad, using hand brake. I finally arrived at the point of syncing to my ipad, only to find there isn't any sign of a device on my laptop. Any ideas how to put it on or do I spend another frustrating day, losing my temper! And please answer in English- I'm too old and doddery to understand computer speak. No initials, no new words or technical lingo.
Sep 2, 2007
Austin, Tx
Some things to check / try:
-- Make sure iTunes is running on your PC
-- If it is, try a restart of the PC and a reconnect of the iPad
-- If it's still not being seen, try a different USB port on the PC
-- Try a different sync cable if you have one available
Some things that would be useful to know to help further:
-- Are you using a Windows PC or a Mac?
-- Has the iPad ever been recognized properly on that PC?
-- Do you see any error messages in iTunes?
