How do I install a custom carrier icon?
jamiemiller
Nov 18, 2008
95
North America
ok they are in 2 locations and there are 2 files to replace.
found in system/library/carrier bundles/ATT US.bundle
2. replace the same files
found in /var/mobile/library/carrier bundle. bundle__________________
Followed that didn't work still, can someone explain number 2 step better. should they be renamed to default_carrier_att.png and fso_carrier_att.png instead of _fido's (my provider) which is in that folder?
x4x5x1x
Sep 12, 2007
101
Wyandotte Mi
www.myspace.com
ok...i assume you are in canada as you have fido. in step one you were told to replace it in the att US.bundle well look and see if there is a canada one. give that a shot and let me know. ill ssh into my phone tonight and look around too.
as for step two, yes you replace the files with the same names as in step one.
jamiemiller
Nov 18, 2008
95
North America
OK
:p OK. So i looked and found the Fido_ca bundle in the first step... But the pics of the mudflap chicks from step 2 i already installed were already THERE!
Can i show u the pics i am using... and tell me if you can use them.. if u can use them i wanna see a screenie!
