How do I play an album in iTunes?
RyanP
Jul 26, 2007
51
I'm new to iTunes (only started using it since I got the iPhone)...tonight I was trying to play just one cd within iTunes and could not figure it out! I apologize if it's a dumb question, but can somebody tell me how to play just one cd (ideally I could shuffle that one cd...but currently when I try to do it, it just jumps to a random song from another cd after it finishes the first song from the cd I want to hear). Thanks,
Ryan
BamBam
Aug 30, 2007
95
Ohio
Browser is your friend...
Hi,
One way to do this is to ensure 'Browser' option is active.
Browser is active when you can see Genre, Artist, Album columns in separate lists above your song list window. If not, go to VIEW menu and select 'Show Browser'.
Now make sure the shuffle button (bottom left) is not active.
Next, select your album in the Album pane (far right in Browser).
Click play (or hit space).
Hope this helps.
RyanP
Jul 26, 2007
51
Thanks! That's exactly what I was trying to do! I appreciate the advice (especially to this older post--I had given up on it).
Ryan
exiled_to_texas
Jul 31, 2008
That did not work for me.
Is it iTunes version dependent?
Maybe has to do with the way the cd was imported?
I've tried changing the properties using get info with all songs selected. No luck.
Thanks...
Timbo
Aug 20, 2008
Hi there. Didn't work for me either. I'm running iTunes 7.7.1.11.
Looks like I have to individually check each song on the album if I want it to play through. Is this the case?
Tim
