How do I put movies on iPhone 3GS?
JEEPER
Aug 23, 2009
What is some iPhone must haves? I would like to be able to put movies on my 3Gs anyone know how? And what else do I need thanks in advance!:cool:
iphonewarrior
13,847
701
You movies will need to be in mp4 format. There are loads of different converters you can download straight over the web.
You can download Handbreak. It works effortlessly.
Once it's converted into the appropriate format, open it up with iTunes and sync it your phone, like you would a song.
iphonewarrior
13,847
701
Like I said, there are various video converters available. Try a few out, find the one thats right for you.
JEEPER
Aug 23, 2009
what other one do you recommend
iphonewarrior
13,847
701
It's good as it had all the preset settings for different devices. You can just check which one you want, hit convert, then your done. It really is easy to use.
It's not the fastest converter but it does make life very simple when using it.
iphonewarrior
13,847
701
There is a thread on video conversion etc on EIC. I'll try and find it and update my post.
RossMc
Jun 28, 2009
1,124
Newcastle, UK
I use Xilisoft Video Converter Ultimate
Only because I managed to get a legal licence free :D
RossMc
Jun 28, 2009
1,124
Newcastle, UK
Its all Legal lol
I was using the Trial version and it poped up with a Alert saying you can get this software for free from our sponsor Trial Pay so I clicked it signed up for a trial at E-Music then they sent me the licence code and I used the trial then cancelled :D
Jan 16, 2009
3,230
59
Mississippi
I actually paid $29 for Magic DVD Ripper. They have a trial if you want to try it. I tried Handbrake and couldn't quite get the hang of it. Plus this program does a movie in 30-40 minutes and I had 400 to do. I also like how I can stick in a NCSI season disc and do all 4 episodes in about 35 minutes and it names them right. Of course I'm sure Handbrake and others will do multisessions as well. This is just another option for you.
JEEPER
Aug 23, 2009
Thanks everyone I got hanbreak to work! THANKS A MILLION:eek:k:eek:k
