How do I put themes downloaded on my PC on my iPhone?
Dec 13, 2007
25
utah
I found a site that has lots of cool themes and icons. the only problem is that once I download them to my pc, how do I put them on my phone? so I have to ssh each individual file to to correct folder. it seems that there should be an easier way.
here is a link
http://planet-iphones.com/downloads/
thanks
Chris716
Nov 29, 2007
807
IL
does that work on 1.1.2 OTB I've never tried it
Spoolin414
Dec 6, 2007
93
Ft Lauderdale, FL
As far as I know you can put the whole directory into the Summerboard app via ibrickr or winscp.
Chris716
Nov 29, 2007
807
IL
ah ok i will try it out shortly thanks..
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
Winscp works very well with 1.1.2, just make sure you have SSH installed to use with your wi-fi to upload the files.
Dec 13, 2007
25
utah
Ya I use that winscp , I think it works really well. I did try to put a whole theme folder in the summerboard and it still wont work, let me know what you find out works
thanks
Dalton
