How do I remove jailbreak and completely restore as new?
irookie7592
Dec 3, 2012
Waterlooville
I bought an iPhone 4 off i guy i know and he said it's jailbroken. I just want to completely restore it as if i just bought it brand new. I don't know what he used to jailbreak it but he seems to think it could have been redsn0w but not certain. I've tried restorin through iTunes and am currently trying to erase all data and settings through the phones menus.
Any help would be much appreciated, really wan this back to normal!
Cheers :D
emhcee
Apr 4, 2008
246
Just to be clear, when you say you've tried restoring through iTunes, do you mean you used the shift-option restore method? This should prompt you that you're going to take it back to factory base setup.
emhcee
Apr 4, 2008
246
Well for me, I have the option to select a firmware when I hold the Option button down and click Restore. But when I hold the Shift key and the Option key and click restore, it checks with Apple and does a factory restore. Sorry, I didn't realize that it looks locally for a version of the firmware when doing it that way. (And I can't test it, as I don't want to go down the route of restoring my phone! :) )
Just select 'update' in iTunes. It will download and install the latest firmware and remove the jailbreak. You don't have to restore to factory settings unless you're having problems with it.
Don't use the 'erase all content and settings' feature in the settings app on the phone if it's jailbroken. It causes it to get stuck at the boot logo and then you'll have to restore.
