How do I restore my iPhone with SW 1.0.2
Macabel
Oct 10, 2007
My iPhone has SW 1.0.2 and I need to restore it to the original factory settings. I need to get the original font files, cause they were modified in Thailand where I bought the phone. Thanks for the help!
papabro
Jul 23, 2007
101
MA
There is a restore function in iTunes that will restore your iPhone back to the factory settings. It will also erase everything ( music, contacts etc ) on your phone. You should sync it before you restore.
akophone
Aug 1, 2007
300
Connect your phone to your computer.
Sync if necessary.
In iTunes, if it asks you to update to the new firmware (1.1.1) and you want to stay at 1.0.2, do not update!
PC: right click Restore and select 1.0.2
Mac: control click Restore and select 1.0.2
You may even want to disconnect your internet to be sure.
