How do I sync my contacts from my iPhone back to my outlook 2007?
vrsc
Jun 22, 2007
204
Orlando, Fl
How do I sync my contacts from my iPhone back to my Outlook 2007? I have added some more contacts to my iPhone while on vacation away from my PC and want them added to my outlook. Is there away to do this or do I need to re-create them in my outlook on my PC?
wjp09
Feb 25, 2007
2,559
25
NJ
Could you elaborate more? How did you do this etc. It could be helpful for others.
vrsc
Jun 22, 2007
204
Orlando, Fl
Actually, it automatically syncs from your iPhone back into your outlook if you have it set to automatically update whenever you plug your iPhone up to your comp. If you;ve changed more than 20% of your contacts or calendar (added more contacts or events onto your iPhones calendar or contacts) iTunes will give you a pop up screen asking you if that is ok. So pretty easy!:cool:
