How do I teach Siri who is my girlfriend or sister?
bluejak
Oct 4, 2015
31
I have tried but she says she cannot find it in contact s, and cannot add it. I have tried putting them in contacts but she still cannot find them.
I have read you can say to Siri "Send a text to my girlfriend" or some such but it does not work.
5,580
Adding them in as a nickname works for me.
Is this how you added them in?
Contacts > Name > Edit > Add field > Nickname
5,580
@Europa does it make a difference if you have your contact default account set up not with iCloud ?
No. You can add nicknames regardless of the method that you use to sync and backup your contacts.
K.C.
Nov 15, 2011
120
44
California
Or just tell Siri who is who. Works for me.
bluejak
Oct 4, 2015
31
I have tried putting wife into nickname and Siri does not recognise who my wife is. I have told Siri to my wife, and Siri still does not know my wife is. Despite doing what is recommended above, it just does not seem to work.
Ledsteplin
Oct 29, 2013
4,853
1,004
66
Florence, AL
Try disabling Siri, do a hard reset, then enable Siri and try again.
bluejak
Oct 4, 2015
31
That has made I better, but ..... It now knows my sister is Liz Verran, and Liz Verran is in my contacts. If I ask Siri to find Liz Verran she shows the full contacts. But if I ask to text my sister Siri says she has no eddress or phone number for Liz Verran!
Rafagon
Dec 7, 2011
7,567
1,254
45
Miami, Florida
First, make sure you've created a contact card for yourself, and one for each person (wife, sister, etc.) in your life that you wish to be able to call (or text, e-mail, etc.) using Siri.
Go to your contacts and select your own contact card, tap on Edit, scroll down to "add related name", pick a relation ("wife", "sister", etc.), then select the [previously created] contact card for that person.
You can "Add Related Name" as many times as necessary for all the people in your life.
Then go to Settings > General > Siri > My Info and make sure your own contact card is selected.
Finally, do a test run to be sure it's working.
Rafagon
Dec 7, 2011
7,567
1,254
45
Miami, Florida
Note that you can also create custom labels. If you don't see "girlfriend" in the list of relationships (you shouldn't, unless you previously created it), tap on "Add Custom Label" at the time of contact linking.
bluejak
Oct 4, 2015
31
Ahah! I was just about to point out that the three labels were Spouse, Manager and Assistant. I shall try that.
bluejak
Oct 4, 2015
31
Nope, doesn't work. No custom labels available.
bluejak
Oct 4, 2015
31
Yes, 9.0.2. I have 10 of those missing! I have only 3, spouse, manager, assistant. No custom.
5,580
Try turning off contacts for Gmail/Exchange and enabling iCloud contacts.
bluejak
Oct 4, 2015
31
I don't have any for Gmail or Exchange. I changed Hotmail to ICloud, turned off Hotmail, lost 100 contacts, nothing else. I have recovered the Contacts but otherwise as before.
5,580
You won't lose your Hotmail contacts. Start syncing them with iCloud before turning off Hotmail contacts. That will save all of them to iCloud. The labels and Siri problem might be a trade off if you would prefer to stick with Hotmail syncing.
15,385
1,089
nm, raffy already got it, missed his post.
bluejak
Oct 4, 2015
31
I shall keep fiddling with it hearing all that everyone says. So even though this has not solved it, it has given me some ideas. Thank you all
