How do I transfer CD music from iPhone to laptop?
Antmf
Jul 29, 2008
42
Hey guys, I just got a new laptop and transfered my purchased songs over to my laptop and authorized it etc. but how do I transfer the songs from my iPhone that I actually downloaded into iTunes from my store bought CD's? Is there a way to get all of these songs on my iTunes library with out uplaoding all of them from cd's again? That will be to much work lol. Thanks...
iNinja
Aug 8, 2008
3,984
20
UK
You cant do this natively from the iPhone. Download some software like i-funbox or diskaid and you can transfer all your iPhone media to your computer.
6,682
49
another method is to use iFunbox. Free software that you can use to pull off all you music and then put it in the iTunes music folder. it would be a "new" library, but it's exactly what you had before.
I also believe that photos and even Notes can be salvaged from the iPhone this way as well.
iNinja
Aug 8, 2008
3,984
20
UK
Im sure I mentioned that software in my post Hawk ;)
5,578
A third option, which has yet to be mention and is the best method IMO, would be i-Funbox ;)
http://i-funbox.com/
Jul 22, 2009
20
From iTune I do not think it is possible. iTunes is a good apps for iPhone but still it lacks efficiency and flexible options in using. That is why sometimes this apps give pain. You should look for some other compatible software.
6,682
49
The article dtuner posted actually tells you how it can work, while the rest of us already offered the best possible scenario software.
Antmf
Jul 29, 2008
42
Thank yuou for all your help... But now I haver one more problem... I have downloaded Ifunbox but it says it does not recognize the files on my iPhone 3g 3.0 not jailbroken. HOw can I fix this? Thanks...
6,682
49
It's possible you downloaded an earlier version not compatible with the 3.0 software.
This is what mine is.
