How do I transfer contacts and pictures from iPhone 3G to iPhone 4?
Micker
Sep 9, 2010
How do I transfer contacts and pictures from my iPhone 3G to iPhone 4? I'm not very computer savvy, so need detailed instructions. Thanks.
Micker
Cjvdh
Mar 8, 2009
3,447
81
York, PA
www.twitter.com
All you have to do is plug your old phone into iTunes and right click on the name of your phone on the left hand side bar and hit "Back Up" once that is completed then you plug your new phone into iTunes and set up as new phone. Once that is complete then you can restore from back up. Good-luck and let us know if you need anymore help.
btitus
Apr 7, 2009
501
26
North Carolina
How do I transfer contacts and pictures from my iPhone3 to iPhone4G? I'm not very computer savvy, so need detailed instructions. Thanks.
Micker
Using iTunes you should be able to use the same photo folder you used to sync the photos onto your previous iPhone. Just check the folder that you want to sync
