How do I transfer my iPhone/Mac Contacts to my work laptop Outlook
JimmyF
Sep 8, 2011
Hi...I have a ton of contacts in my iPhone and Mac but just started a new job and would like to transfer them to my HP laptop Outlook....How do I do that without having to input by hand? Thanks so much, Jim
Kadelic
Jan 4, 2010
4,957
1,609
Dallas, TX
Open Address Book on your Mac and open it to all contacts. Command A to select all, then go to File>Export>Export vCard. You should be able to import this file into Outlook.
Lon
Jun 5, 2010
2,946
132
Alaska
Kadelic provided probably the easiest solution. I thought maybe if you synced through Google that would be an easy method also.
JimmyF
Sep 8, 2011
Thanks Kadelic...So far I e-mailed the vCard file on to my laptop...I don't know how to merge it into outlook? Any ideas?
Lon
Jun 5, 2010
2,946
132
Alaska
Under your file menu in Outlook go to Import Files and import the file you just created.
