How do I transfer video from iPhone to computer?
Vpeach
Jun 30, 2007
74
My boyfriend reformatted his computer and no longer has his video files on his computer. Before he reformated he transfered the videos to iTunes and put them on his iPhone.
He wants to get the videos back on his computer now so he can have a backup incase he has to restore his phone.
Any ideas?
420greg
Jun 26, 2007
845
Orlando, Florida
Any ideas?
This is a link to the mac version, but there is a link to the PC version on the page.
http://www.findleydesigns.com/ipodaccess/index.html
Grifftech
Dec 14, 2007
46
I can't figure out how to Sync my photos from iPhone to iTunes to make sure i have them saved.
My wife and I use the same PC and am trying to figure out how to backup the Photos from hers and my phone into iTunes. Or is there an easier way?
BrownGem
Feb 27, 2009
1,623
23
Texas
With iPhone connected and iTunes open, click your device to open the tabbed window for sync options. Click on photos tab and put a check in "sync photos from" >>> my pictures folder is already listed in the box. Then put a dot in selected folders. Put a check in iPhone desktop. It will sync your device pics to the pc. You may sync any pics from that folder and that option will appear in the list if you have any already on the computer. Similar process with videos. Click sync and select your options. The box has options of what to sync if you click the small arrows inside...all unwatched, etc.
Grifftech
Dec 14, 2007
46
I made a new folder on my Desktop called iPhone Photos. I put the Check by Desktop and Selected iPhone Photos and ran a Sync and nothing was put in the iPhone Photos folder, it is empty still
BrownGem
Feb 27, 2009
1,623
23
Texas
Try selecting the pictures folder or creating the iPhone Pictures folder in My Documents. You can always put a shortcut to the desktop for this folder. It may be the folders' location on the desktop causing a problem?
superman21
Jul 2, 2009
When you plug in your iPhone, your computer should automatically detect it as a digital camera. Open My Computer and it should be listed there as [Your name]'s iPhone. Simply double-click to open it and all photos and/or videos captured with the iPhone should be there and able to be copied/backed up. iTunes itself cannot handle importing of photo/video from your iPhone.
Grifftech
Dec 14, 2007
46
Shane Watson said:
I think iPhone is one of the easiest way to do something when you fully understand. Just sync it and you will get what ever you want in the right places.
Oh great reply Captain Friggin Obvious, maybe some direction ftw.
Chicki
Jul 5, 2009
Can someone tell me how to sync the photos from my iPhone to my desktop? Thanks.
superman21
Jul 2, 2009
See my post above. There is no way to sync your photos from the phone to your computer like you do through iTunes. Your computer automatically detects the phone as a camera and lets you simply copy/cut-paste them right off the phone.
edoco
Jul 18, 2009
Import Photos from iPhone (Works on Vista Home Premium 32bit)
I wasn't able to open the iPhone folder and copy and paste to my desktop either so I explored other solutions.
Once I plugged my iPhone into the computer it appeared in my computer.
I right clicked the iPhone icon and there it was the magical menu item that everyone seems to want. "Import Pictures" Now I am using MS Vista Home Premium and that may the the difference between others who cannot import. But this worked for me and there were options as to where to store what to name copy/move(delete from device) etc. So Hopefully if you have photos/videos on your iPhone you can use this method.:)
shyreep
Oct 22, 2008
I had my old laptop stolen and have just downloaded iTunes to my new pc, now i want to transfer all the photos on my phone, (ie: the photo library) to my new pc so i can retrieve some of the pics that were taken but it's only transferring the pics on my camera roll, not the photo library.. Please help!
5,580
This should work. http://i-funbox.com/ It will also allow you to transfer the music from your iPhone to your new computer.
Another way would be to email the pics to yourself.
energybell
Dec 3, 2012
When you click on the photos tab (within iTunes), you then need to click on browse folders, so that you can then see them under a date that you did your sync!
topcat84
Jun 28, 2007
294
Hi Everyone,
I've done a search but haven't found the answer on the steps needed to put my iPhone videos onto my computer. Thanks in advance. Cheers !
Kriss
Jun 8, 2008
598
121
43
Cape Cod
voyager01.deviantart.com
That's a good question. I have a Mac and I import the photos into iPhoto, then export them into a folder. If you don't have iPhoto, I think you'd have to email them to yourself, or perhaps create a dropbox account and save it to there. I know there are apps that allow you to access them from a browser window as well as do wifi transfers.
Kriss
Jun 8, 2008
598
121
43
Cape Cod
Here is a link for if you have windows vista or 7. (there is also a link on there for windows XP)
http://support.apple.com/kb/HT4083?viewlocale=en_US&locale=en_US
