How do I turn edge off when roaming?
afsilverman
45
Just wondering i heard that with this new update you can now turn Edge off when roaming so you can use the phone but not receive emails or Internet and get $$$$$$ in roaming charges,
I have not found this can some one please tell me were to look in settings. Thanks.
Also what is this Data Roaming switch do? I don't understand do i want it switched on or off?
Kanyon71
Sep 5, 2007
11
Data roaming off is what kills the phones ability to roam edge when out of your provider. Thats pretty much what you're looking for.
Marianne
2,326
29
Massachusetts
marianneschultz.com
You already found it. That data roaming switch is what you need to switch off data access while you're out of the U.S. Edge is the data network.
afsilverman
45
thanks
so when im roaming i want it to be in the off position and when im home i should turn it to on?
afsilverman
45
im in my home network and its on off should i put it to on?
Marianne
2,326
29
Massachusetts
marianneschultz.com
i don't think you need to, unless you travel regularly and think you'll be prone to forget to turn it off before you go on a trip out of the country and rack up roaming data charges without knowing it...
