How do I update to iOS 5.1?
Nur2652
Aug 1, 2010
114
How do I update my software to 5.1 without the update option. I hit general then about and that's where it ends. My friends 4.0 is running on 4.3.5 wow. Thanks.
Nur2652
Aug 1, 2010
114
At work don't have iTunes here, I'd there any other way to get it? Thanks.
Nur2652
Aug 1, 2010
114
My phone has what you said but the one I'm trying to update doesn't give me that option. I hit settings, general but software update doesn't come up. I don't know.
Kadelic
Jan 4, 2010
4,957
1,609
Dallas, TX
The over-the-air software update option is only available for iOS 5.0 or higher. For anything before you'll have to use iTunes.
applejailescape
Oct 5, 2010
1,155
20
27
Ireland,UK
Try and get someone with iTunes on their computer and borrow that , will save confusion .
-Spencer-
Girdler
Aug 1, 2012
283
44
30
The only way that you'll be able to update your phone is through iTunes. Once you updated to 5.0+, you will then be able to use the OTA updating. Until then, iTunes all the way. (y)
