How do I use AirPrint
jafundy
Jul 5, 2007
216
11
I have an iPhone 4. Can't find an option for AirPrint. How does this work?
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
There's nothing to set or setup for it on the iPhone. Just got into an app that supports the feature - e.g. Mail, Safari, Photos - and tap the standard Share button. That will show you Print as one of the options.
The hard part is having a printer that is supported by AirPlay - the list at the moment is very short, featuring just a handful of HP printers. You can find the list here:
http://support.apple.com/kb/ht4356
5,580
Use Printopia....I just downloaded it.. piece of cake!
http://www.ecamm.com/mac/printopia/
Check out this page and follow the instructions there.
http://jaxov.com/2010/11/how-to-enable-airprint-service-on-windows/
I tried it yesterday and got my HP dinosaur to work just fine.
These all require installation on a computer and the computer must be turned on for Air Printing to work (so it can route through it). TruPrint, available in Cydia, enables AirPrint on the iPhone without being dependent on a computer.
