how do you change/add txt sounds?
NickT916
Jan 4, 2008
266
i got an unlocked jailbroken 1.1.4 i cant figure out how to change txt sounds..
i read you have to download SHH but i cant find it on my screen, how do i use it? and then you have to go to like systems, audio, then change the file extension and replaces it with stock file? thats great butits just that i don't know how to open SHH or how to get to systems and sounds etc,
todesto
Sep 30, 2007
59
if you search with custom string, you will find out how to do it. It takes a time, but doable. First you need to create .caf file with the sound file you want to use. But from seeing what you wrote, you need to learn to access iPhone vis SSH. Please search more.
go check out www.hackthatphone.com
