How do you delete photos....
gmaghaki
Jul 12, 2007
Sorry if this has been asked previously, but how do you delete photos on the iPhone? Do I need to go through iPhoto or can it be done on the iPhone?
Blooz4u
Jul 10, 2007
14
I believe you just tap the photo once and it brings up options on the bottom of the photo. One of them is trash can. You just click the trash can and the photo is deleted!
Iwantmymtv35
Jul 2, 2007
134
You can't, unless you go through iPhoto. You can delete pictures from your camera roll though, but not the one's from the Photo Library.
greenjbhsd
Jul 13, 2007
571
I just click the home button/photos/photo library - then click the photo, it opens, then hit the trash can on the bottom of the screen. Or is that not what you mean?
Iwantmymtv35
Jul 2, 2007
134
Do you have a Mac or Windows? If you have Mac iPhoto is a program, but if you have Windows, you can just go and delete those pictures out of where it is syncing them, or make a separate roll where you can put the pictures you want on the iPhone.
Hope this helps,
Evan
BubbaJun
Oct 19, 2009
still having trouble deleting photos
I have a laptop with Windows XP and an unlocked iPhone and I have tried a couple different ways to delete photos without much success.
the first way is by pluging the iPhone into my computer and selecting the option to delete the photos after uploading them. I have tried this several times and every time it gets as far as two or three photos and then the iPhone reset itself.
the other method is to delete them through windows explorer. I can delete the one at a time no problem but, every time I try to do more than 3 or 4 at a time, same thing happens. the iPhone restarts itself and my photos are all still there. I'm not sure what to do but at this point over half the photos on my phone are old ones that I have already uploaded, how can I get rid of them?
thank you for your help.
asctony
Jul 30, 2009
117
MI
I use IfunBox.exe which is much better than other apps such as iPhoneBrowser. You can add and delete via IfunBox. I have added movies, pics, files, etc. To add Files to IfunBox - Just open File Explorer (I use Total Commander on my PC) drag and drop the file into IfunBox. To Delete - Just use IfunBox, go to the file and delete. Hope this helps you and others. If you run into a problem, just let me know. :eek:k:eek:k
