How do you disable Edge?
lotecorp
Mar 3, 2008
32
I don't have data plan with att and don't want to use edge unless I need to. Thanks
for the information
DavidB
Sep 26, 2007
If you don't have an att plan, presumably you are jailbroken/unlocked. In Installer, download and install "Services". This gives you the ability to toggle Edge, Wifi, Bluetooth, and SSH on and off (independently of one another).
DavidB
Sep 26, 2007
Oh my...you are right. I don 't know when that quit working, must have been with 1.1.3 or 1.1.4. I haven't really used the edge option since Apple came out with the "Disable Data while Roaming" option, since that was my concern...
I'll fool with it to see if I can try to figure something else out. Sorry to get your hopes up.
