how do you get 5th icon on dock?
reebs
Jul 11, 2007
146
hi, wanted to add a fifth icon in addition to safari, phone, mail, ipod. how do i do this? do i go into the terminal and reorder through display.plist? or can i do it through ifuntastic? I'm on a mac. please help. thanks!
rinual
Jul 18, 2007
49
you just edit your displayorder.plist using notepad and put it back inside springboard
one section of the code shows the 4 icons that would be on the dock, just add the 5th icon and your g2g.
hope that helps
DiscoJoey
Jun 5, 2007
307
hope that helps
does this really work? i know once you fill the 4 extra spots on your springboard you cant add a 5th one. well you can but you just cant see it. i never tried with the little bar on the bottom though.
rinual
Jul 18, 2007
49
sorry if i didn't make myself clear, however if you go to this link, download it and view how they did their displayorder.plist
http://www.modmyi.com/forums/downloads.php?do=file&id=241
<key>buttonBar</key>
<array>
<dict>
<key>displayIdentifier</key>
<string>com.apple.mobilephone</string>
</dict>
<dict>
<string>com.apple.MobileSMS</string>
</dict>
<dict>
<string>com.apple.mobilesafari</string>
</dict>
<dict>
<string>com.apple.mobilemail</string>
</dict>
<dict>
<string>com.apple.mobileipod</string>
</dict>
</array>
if you notice, it uses all 5 in the bottom bar array. and if you look at the icons, they are much smaller than the usuall stock icons.
