How do you get your springboard to have zero icons?
FantaXP7
Aug 12, 2007
35
How do you get your springboard to have 0 icons? I have tried it within customize and it never works.
Also, I can't get Dock to work. When I install and click on the sunburst, a bunch of icons flash across the screen then it opens up calculator...
Anyone have a solution?
Just go into Customize > rSBT, and drag all of the icons into "Hidden".
When in Dock, be sure to keep your finger on the screen, and let go when you're on the icon you want. It's a bit tricky at first.
projkt13
Oct 22, 2007
25
Oceanside, CA
I've had that problem too. Even when I drag it to hidden! But I found a thread where you can make the icons transparent so I used that instead of clearing my interface.
