How do you manage icons?
Banzai
Aug 24, 2007
44
As I add mods I find that my "launcher" icon (the one the lets me see more than 16 icons) is being pushed out.
Is there an app that allows you to manage your own icon priority? Something with an interface that drags and drops like the ipod configuration tool for editing icons?
wildonrio
Jul 4, 2007
2,002
Provo, UT
There's no app that I'm aware of, but you can do it manurally. Go to System/Library/CoreServices/Springboard.app and look for DisplayOrder.plist. Copy it to your desktop and open it with an HTML editor, or you can use Notepad. What you need to look for is <string>APPLICATION NAME GOES HERE</string>. Move around the order of the applications within the <string> and </string>, save it, upload it back onto your phone, and then restart.
By the way, if you want to also reorder the third party apps, this is a bit more tricky. You need to get the <string> code from the Info.plist file that is in the specific app's directory on the phone and move it over that way. Make sure you write in everything else that goes before and after the <string></string> like your Apple certified apps in the DisplayOrder.plist (they all start <dict> and end </dict>). Let me know if you have any questions.
i3fan8760
Jul 27, 2007
29
Im sorry but i have no idea how to do all that can u please tell me step by step? Thanks in advance..
wildonrio
Jul 4, 2007
2,002
Provo, UT
Ok first you just need to navigate to that directory I mentioned earlier. To get there you need to use a program like Manzana, iBrickr, or WinSCP. If you get that far, my earlier post should make a lot more sense.
i3fan8760
Jul 27, 2007
29
Thanks i did that but when i open the files its giving me a bunch of gibberish like i don't have a codec or somethin
bnelse92
Jul 29, 2007
ifuntastic allows you to reorder home screen layout by drag and drop. Don't know if it plays well with 3rd party apps though.
wildonrio
Jul 4, 2007
2,002
Provo, UT
That's why you should google and download an HTML editor so it doesn't look all messed up.
Kipper
I had the same prob. like a week ago and I was messing around looking for things then I finally figured it out and did the same method like wildonrio said and it works like a charm now.
garretwp
Sep 3, 2007
125
If you have the installer.app installed on your iPhone, why not use rSBT? This app allows you to reorder your home screen the way you want it.
- Garrett
