How do you select a playlist to sync in iTunes
Feb 2, 2012
I have an iPhone 6 and have had every version of iphone. I went to sync my phone and wanted to sync a new playlist I had made, but there is no option to do this. I used to go into Compaq administrator iphone and go to the playlist tab and select the playlists to be sync'd. I cant find that option anymore. Help.
Rafagon
Dec 7, 2011
7,566
1,254
44
Miami, Florida
I searched for "Compaq Administrator iPhone" on Google and found nothing, so I'm not exactly sure what that is.
Perhaps this is a folder on your computer that contains administrative software... including perhaps iTunes for Windows?
If so, start the iTunes application.
If the iPhone icon (as indicated by arrow #1) isn't visible, connect your iPhone to your computer using the Lightning cable. Then, on the iTunes application, click on the iPhone icon I just mentioned. Then click on Music (#2) and then place a checkmark by the playlist(s) you want to sync as indicated by arrow #3. Finally, near the bottom right of the iTunes screen, you will see a
button. Click on that and let the sync finish.
Note: The above screenshot was taken on iTunes running on OS X, so yours may look slightly different.
