How do you sync ringtones when iTunes is set to manually sync? Need help!
Chad711
Nov 20, 2008
I just recently purchased a iPhone. I consider myself a pretty technical person but I must say I am stumped on why I cannot get my ringtones to sync with out my music and videos on my iPhone being erased each time. I can overclock my computer but I can't sync a ring tone! LOL
Any way here is the deal. I am converting my songs in iTunes to ACC and then renaming them to m4r files. I drag it back into the iTunes library where I see it in the ringtones area of iTunes. However here is the problem. I manually sync music on videos for my iPhone because I don't want 2000 songs on my iPhone! So when I go to try and sync my ringtones it gives me a pop up warning stating that "Syncing ringtones will delete music and video from your iPhone. Are you sure you want to do this?"
So my question is two parts. How do I sync ringtones with out losing music/video data on iPhone and how do I get the ringtones to show up in the sync area of the iPhones "Ringtone" tab? I try to drag it from ringtones iTunes library to the iPhones ringtone library but it does't show up on the Ringtones "tab". Sorry if it sounds confusing.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
What do you mean that it doesn't show up in the Ringtones tab?
I had the same problem a while back and all I had to do was manually drag and drop the ringtones onto the iPhone just as I would with music.
Chad711
Nov 20, 2008
It's hard to explain. I would need to show you a few screen shots to explain it. Anyway,
I tried to drag it into the ringtones folder on the iPhone. It actually shows up there. However it's odd because it isn't on my phone. So basically it didn't sync. So after I saw it there I went to the tabs that shows the options for sync for each feature of the iPhone (music, apps, rintones, videos, etc) The ringtone does not show up in the sync area of "Ringtones". If you are lost then when I get home I will post some screen shots.
Chad711
Nov 20, 2008
I manually sync items just like you do. I drag movies and music over to the iPhone and done. However the ringtones do not want to cooperate that way. So what I did last night was drag it to the iTunes library which in turn automatically puts it into the ringtones folder of iTunes. If I go to the Ringtones TAB on iPhone where you can select to sync certain items or all items that is when I click sync. At that point it states if I do it then it will delete my music and movies.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Well the reason I asked is because your ringtones might be too long to sync. If they are just a second over 30 seconds, they won't sync. I'm not sure if this is the problem but it could be.
Chad711
Nov 20, 2008
No they are not. I am going home in about an hour and I will fiddle around with it. I'll report back here if I have problems still. I was rushed some what at lunch time (when I was trying to get it work).
lensam
Mar 8, 2008
60
Bridgeport, CT
The way I did it was in iTunes under devices you click on your iPhone and check under each tab across the top. Music, podcasts, videos apps, etc. Make sure the sync box is NOT checked under these tabs. My phone is set to manually manage so try it that way. If it doesn't work then uncheck the "manually manage" box. Then you go to the ringtones tab and check the sync box and select all ringtones button and then hit the sync button. All your ringtones should appear after that. Once that is done uncheck the sync box and they will remain there. And you shouldnt lose any of your music or videos if I remember correctly. If you do you can always re add the media afterwards. You do have your iTunes backed up, right?!?!? also you changed the extension to r for ringtone
punkit
May 8, 2009
Hi there, i had the EXACT same problem as you and after hours googling the hell out of it repeatedly coming to the same answer i finally figured it out. this worked for me so i'm gonna assume it will work for you seeing as we have an identical problem.. all i did was when the "ringtone" is made and it's in the "ringtone" area of iTunes ie: in the library, under music and apps and whatever else you have there, you know what i mean. i just clicked and dragged it to my iPhone... not to ringtones or music or anything like that, drag it to "chad's iPhone" under devices. it syncs for a sec and then when you go to settings, sounds, ringtones, it's in it's own little section up the top. i hope it works for you, and anyone else with this problem. if my instructions were horrible, lemme know and i'll try to explain it better. good luck
Jul 8, 2009
LOL wow solved the problem.
sync it to the top tab where you would press the "eject" button. DO NOT TRY AND DRAG IT TO THE RINGTONES OR MUSIC TAB.
i feel stupid now ahaha
MrBarnes
Sep 29, 2009
Wauw!
I simply HAD to create a profile just to thank you! I still can't believe it was THAT simple. Drag the ringtone to the iPhone instead of the ringtones folder... THANK YOU!
Geary
Sep 5, 2010
Thsi does not work for me! I do exactly that and I try dragging 2 ringtones into my iPhone but no matter what I only get 1 ringtone in the custom area. I hate this crap that Apple locks you out of everything. I am used to doing things manually. If I sync it wants to remove ALL my songs, music and TV shows! Give me a break Apple I just want a few custom ringtones, I can micromanage my own freakin phone!
mrbunglez
Mar 20, 2008
439
100
43
I use itoner to use my own music in iTunes as a ringtone.
Drag and drop program that syncs.
http://www.ambrosiasw.com/utilities/itoner/
Zoander
Oct 29, 2010
Thank god someone wrote it in a way that I understand! Thanks punkit, i was going mad that i kept losing ringtones every time i synced!
Gary222
Aug 23, 2011
Okay, what you're all saying makes perfect sense, except for one thing. For some reason my iPhone isn't showing up under devices, even though under Preferences, I have everything clicked to show up in the side bar. This is maddening. I can't figure out why it's not showing up. Anybody have any suggestions?
Oct 30, 2011
hi, its the same as before except for the how long the ringtone is? before it was max 30 seconds and now its max time of 20 seconds? hope this helps!
Phaze
Mar 30, 2012
Airdrie, Alberta
Ha! I figured it out. I had the same problem, I wanted to put ringtones on my phone but when I synced I lost all my music. So I unchecked Sync Tones and started putting music back on my iPhone when I noticed that I couldn't use any of those ringtones again. If I went in iTunes and clicked on Tones in the side bar under devices, I could see all my tones. When I went on my phone, I couldn't find them. And furthermore it looked like you would have to sync tones again, which I didn't want to do.
I solved the problem and I have custom ringtones on my iPhone without syncing or using any kind of apps
So after you have your ring tone finished on your computer, drag the file from it's folder on your computer to the iTunes library.
Then you click and drag the tone from the iTune Library/Tone (you find this in the left hand side bar of iTunes) to your iPhone Device.
Now when you click on your iPhone Tones in the left hand side bar of iTunes, you will notice that your tone is written there normally instead of if you tried to drag and drop from your computer folder to device (those files will come up slightly faded)
This is a two step process
This is one of the reason's I loathe iTunes
I hope this helps you guys
