How do you transfer music?
tunman
Jul 27, 2007
How do you transfer your music from iTunes to your iPhone. Will it not let me do it like my iPod? I have my albums loaded into iTunes but when I sync it doesn't load them onto my iPhone. It says it's syncing, albums are checked but nada.
princess_80854
657
With the iPhone connected, did you go to iTunes to the MUSIC tab and select "Sync Music" and check which songs, playlists you want to sync with the phone? That should fix your problem.
mike3141
Jun 22, 2007
47
You have to define one or more Playlists in iTunes and put albums/songs into them. Then select which playlists are to be sync'd onto your iPhone and then hit the Sync button.
tunman
Jul 27, 2007
How do you select which playlists to be synced?
Is there a tutorial for how to transfer songs?
I have several albums under my Library > Music. Shouldn't those just SYNC with my iPhone if all the songs are checked when I click SYNC?
tunman
Jul 27, 2007
So I created a new Playlist called Albums and put several albums in there. All the songs are checked.
Then I go to my iPhone then Music then SYNC and it says SYNCING but no music transfers.
princess_80854
657
Connect iPhone
Go to iTunes and click on your iPhone name on the left under the DEVICES tab
Click the MUSIC tab and select "Sync Music" and check either ALL SONGS AND PLAYLISTS or SELECTED PLAYLISTS and choose which playlists you want to sync with the phone
Then click Sync
RomeoSto
Jul 6, 2007
59
Chicago IL
Not unless u have the play list set to sync under your iPhones options on iTunes using music tab after u have your iPhone selected.
tharmsen
Jul 5, 2007
873
You see this, then hit Sync and it still doesn't transfer any music?
jaywoodz
Aug 24, 2007
I cannot trasnfer music to iPhone, I just activated it. Can anyone help? It won't transfer like my ipod does.
the.spook
Aug 26, 2007
Same problem
Hi,
I'm having the same problem :(
I can sync my calander, contacts etc.. but not music. And I can't see the screen anywhere like in the screenshot tharmsen posted?
When i click on iPhone in under my devices, I get the message you see in the attached JPEG.
Any ideas?
the.spook
Aug 26, 2007
Like I said, IT IS SYNCING the other items, just not music.
I have to right click on my iPhone under my devices, then select sync... no music syns :(
Kipper
When u dock you phone and load up iTunes there should be a music tab in the middle near the top of the screen. Click that tab and select sync music and all songs and playlists. Then click the sync button on the bottom right hand of the screen. Try that.
