How do you upload your music?
Otacon132
Oct 19, 2007
I have to create a playlist and select that playlist in sync to upload......
is there a way to drag/drop from your "Music" library straight to the iPhone i tunes?
GSA190
Oct 29, 2007
401
New York
While first plugging in your iPhone via dock their should be an option where you can choose what you would like to put into your iPhone.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
When you plug into iTunes, your phone will show up as a device just below the Green iTunes store in the left sidebar.
Just hi-light the the phone device and then you see the summary, music, video bla bla
And this is where you select your playlists in the music section.
In the summary tab, I have selected to sync checked items only. I then have the songs I want checked so that when I sync, only the checked songs are added to the iPhone. No need to use playlists to sync unless you want to.
kokogirl
Sep 8, 2007
2,319
47
Sunny Florida
If you have another music library and want to import music to iTunes, you can do that also. Is this what you are asking?
Otacon132
Oct 19, 2007
well, my old ipod version 2 i was able to manually click and drag songs from my library onto the ipod itself. I haven't owned an Apple product since then and i was wondering if its possible to do this with the iPhone.
When i try and click and drag from the library to the iPhone, it grey's out and wont drag into it. I have 80gigs of music =P so i cant just select the songs. I end up making a playlist named iPhone and set it to sync only that playlist. But id really like to just drag songs in.
termleech
Sep 7, 2007
1,154
McPherson, KS
The short answer is no, not through iTunes you can't manually add music by dragging it. You can only sync playlists.
kakofonix
Oct 2, 2007
596
And the great thing about iPhone playlist is that you don't have to connect the device in order to add to or delete from the playlist, which IMHO, is a better way than the drag n' drop that you're used to with the iPod.
Youngbinks
Jun 4, 2007
7,617
32
Atlanta, Georgia
You can also set it such that it only syncs "Checked Songs" and just go through your library and select the ones you wish to sync and then put the songs on that way.
