How does iTunes Match work?
John Vicente
Oct 19, 2011
San Diego, California
I am curious as to how iTunes Match is going to work. I have an iPad 2 and I originally set it up on a PC computer on the east coast. I have since relocated to California during which time I updated to iOS5 at the local Apple Store. Due to the update, I lost all of my music and now I have the following questions:
If I subscribe to Match for the $25 per year, will I be able to have my family activate it that on the PC computer located on the east coast?
On the east coast computer, iTunes is set up under the same Apple ID as my iPad.
Any info, suggestions or tips would be greatly appreciated before I shell out $25 for something that may or may not work
Michael Baturin
Jul 11, 2007
1,751
244
34
South Jersey
Yes the east coast computer will 'match' all your music to the cloud - and you will be able to download it onto your iPad - from the iPad. Though I think the process may be long (depending on how many songs you have). I am not sure if there is a download all option of if you will have to go song by song.
GailLA
Nov 13, 2007
265
35
Northern IL
So far so good on iTunes Match. Right now it is still checking my library. I have about 400 songs left and it has slowed down, so those may be songs I ripped myself that are more difficult to match. Haven't seen how many I need to upload yet or how that works.
Update: It looks like I have 545 things that need to be uploaded. It is about halfway through. Considering I'm out in the country and uploads on satellite internet are slow I think it is doing well. There are no individual options as to what to upload or not.
flightmedic
Jun 21, 2009
397
23
Wichita Falls, Texas
I have a question about iTunes Match.
I had iTunes scan my media library in order to set up match but I had more then 25,000 songs so I couldn't set it up.
Today, I deleted some play lists so my media library should be less than 25,000. But every time I try to enable Match it says I have too many songs. Is there a way to reinitiate a media library scan to set up Match?
Thanks in advance,
Jim
Kriss
Jun 8, 2008
598
121
43
Cape Cod
voyager01.deviantart.com
Hi Jim. I have iTunes match as well and I believe just removing playlists is not actually removing songs from iTunes. You'll have to physically delete some of your music. My library is over 20,000 songs so I sometimes delete stuff I won't listen to often (or at all). Though I save the actual music files just in case. I've been having a lot of trouble adding songs to my library and having iTunes match scan my media (perhaps because I have my library stored on an external network drive). To answer your question; Yes, you can click on the Store menu and choose update iTunes match. It should rescan your current library at that time. Good luck.
B89rent89
Sep 19, 2012
170
17
What's the limit for iTunes Match? 20,000 songs? I use it but I'm only at 5,000+ songs.
Sent from my iPad using iCafe Forums
Ledsteplin
Oct 29, 2013
4,853
1,000
67
Florence, AL
I doubt I could find 25,000 songs I like well enough to put on my iPhone or even store in the iTunes library. I'm picky about music.
