How Far Back?
ADDam
Mar 2, 2008
439
Ann Arbor, MI
How far back in the iTunes releases do I have to go to get a version where you can edit the carrier file? 8.1?
psylichon
Oct 31, 2007
16,591
751
40
Philly
You can do it with 9.0 if you patch it. It's easy:
Mac OS X:
  1. Close iTunes if it is open
  2. Start Terminal
  3. important]Applications> Utilities
  4. Run the following command: defaults write com.apple.iTunes carrier-testing -bool TRUE
Windows 2000/XP/Vista (32-bit):
  1. Go to Start -> Run (
  2. type in "command" and hit enter
  3. Type/copy+paste this into the command console that comes up: "C:\Program Files\iTunes\iTunes.exe" /setPrefInt carrier-testing 1
  4. Hit enter
Windows XP/Vista (64-bit):
[FONT=Arial, Helvetica]
    • Go to Start -> Run (
    • type in "command" and hit enter
    • Type/copy+paste this into the command console that comes up: "C:\Program Files (x86)\iTunes\iTunes.exe" /setPrefInt carrier-testing 1
    • Hit enter
[/FONT]
psylichon
Oct 31, 2007
16,591
751
40
Philly
Unless you live in Florida, Georgia, or possibly California, don't get your hopes up.
ADDam
Mar 2, 2008
439
Ann Arbor, MI
I live in Michigan. Mine works already, I've had the 5.0 carrier installed since beta, I'm working on getting my girlfriends phone running now
