How long does iPhone stay disabled ?
sam733
Oct 11, 2013
Hi everyone.,
Im a new iPhone user, i updated my iPhone5 with all recent updates from ios7.
I recently changed my passcode and i forgot.
I do remember the numbers used as passcode but i forgot the sequence.
I would like to know how long the phone will be disabled ?it doesn't show any time like in the previous ios
Additional Details
my disabled phone gave an option to enter code after 6 hours, after a couple of wrong tries again its disabled.
i have synced my phone 40 days ago.,
can i restore from that point ?
and if i do will i loose all data on my phone ?
5,578
You haven't backed it up for 40 days? Do you have iCloud backups on? They are automatic once a day. You can restore it from backup if you use the same computer it is synced with, but you'll lose whatever data is new (except what is synced through iCloud if iCloud syncing is on) since the last backup.
sam733
Oct 11, 2013
Thanks for the reply.,
actually i cant remember my last back up, its more than 40 days. :unsure:
and i didn't turned on the iCloud back ups.,
all this is because im using another phone LG Optimus L7.
i recently started using my iPhone and i installed lots of applications and there are many photos & notes.
so i think i don;t have any other option, right ?:unsure::unsure:
5,578
Yeah, you'll have to restore it. There aren't any other options if you can't remember the passcode.
sam733
Oct 11, 2013
i want to try the other possibilities the code which i used.
i used couple of 5's and 6 as my code.
but its not giving me any other option.
i guess i have tried maximum attempts.
does it allow me to enter the code after a day or two. ?
because i don't want to loose my data..
5,578
I want to try the other possibilities the code which I used.
I used couple of 5's and 6 as my code.
I guess I have tried maximum attempts.
because I don't want to loose my data..
Yeah, the time frame gradually increases. Eventually you get to where you can't make any more attempts for about 40 years.
