How long does it take to jailbreak my iPhone 4s in Windows?
TH55
Oct 30, 2011
356
9
I am about to jailbreak my phone with the new Absinthe software, but need to know how long it takes before I begin so I don't get stuck
It can take as long as 30 minutes. Mine only took 7 minutes.
TH55
Oct 30, 2011
356
9
Cool, thanks I am pumped. Does anybody have any recommendations for apps/tweaks? The first thing I am going to do is disable the notification center and spotlight search!
snowtrooper1966
Dec 10, 2009
2,589
1,316
54
Clarksburg, WV
I jailbroke mainly for toneFXs that allows u to thoroughly customize sounds on your device, 5 column springboard and dock (extra app on your dock, extra row on the springboard), nospot (allows u to kill spotlight search) and fake carrier (allows custom carrier name).....
Sure others will chime in with more suggestions.
We can change the carrier name through System Options > Custom Carrier (MakeItMine) in SBSettings now.
chazm
May 1, 2008
729
40
If you don't mind spending a little dough I'd suggest infinidock, navigate from maps (if you use a nav app), mywi (if you need to tether), gridlock.
SBsettings is a must and why in the world would you want to disable the notification center?
TH55
Oct 30, 2011
356
9
Because I constantly pull the notifications tab down by accident, it is to me a completely useless feature since I use badge app icon notifications.
I like Bite SMS, BlurriedNCBackground, BytaFont, Color Keyboard, FolderCloser, iFile, Navigate from Maps, SBSettings, Siri Toggles, Switcher Mod, WinterBoard and 3G Unrestrictor.
snowtrooper1966
Dec 10, 2009
2,589
1,316
54
Clarksburg, WV
I did see that, thanks.
I know I'll catch hell for this, but I uninstalled SBSettings. I don't really use it.
@ OP
I forgot another must have, at least for me.
Action Menu. Adds favorites and some other tweeks to your cursor controlled action menu for frequently used string of txt, for example userId's and (for some sites) the ability to past your password.
I know with iOS 5 they added keyboard shortcuts, but I had already been used to Action Menu.
I also found that stock iOS shortcuts never seem to let you input passwords, a dealbreaker for me and some of my verbose passwords.
shugo
Sep 3, 2011
84
One tip if you are using the 2.0 ver, if you're phone doesn't restart after using the absinth app on the phone after like an hour, then unplug your phone re-run the jailbreak from step one, but before you hit the absinth app again, unplug the phone then hit the app. If it's like mine, then it shouldn't take more than 2 min that way. (Do this at your own risk though, that's what I did to get mine to work, no guarantees that it will work for you)
VOLS34
Jun 25, 2010
1,119
79
I initially had issues with my jailbreak. Had to do a backup in iTunes & wipe everything then setup as new. After that jailbreak was only a few minutes. The restore took about 45minutes.
warren nunes
May 28, 2012
I am currently using v 5.1(9B179)
Modem Firmware: 2.0.10
Is there Jailbeak available for this version?
or can i upgrade it to 5.1.1 and then jailbreak it ?
By the way.. its an iPhone 4s (turbo sim) not factory unlocked..
would appreciate the help!
