how long we can charge the iPhone?
May 3, 2007
i just purchased the iPhone, and after i charge the iPhone i only can used for listening music for 2,3 hours only. when i read the technical specification from Apple.com, it can listening up to 24 hours. i just want to know the real time to charge the iPhone.. Thanks..
regards,
azman
coolie
Sep 18, 2007
131
i think that when you first get it you have to charge it for like a day. i heard its good for the battery
Sep 29, 2007
14
regards,
azman
You should re-read the Apple specifications.
Dawgfan
Jul 27, 2007
347
Atlanta, GA
For the first 3 or 4 charges I would let it go to 10% and then charge for about 6 hours. After than as long as you let it go to 10% or die once a month and do a full charge you should be fine.
You may want to charge it longer on the first one but anything over 10 is unnecessary IMO.
