How many song hold 8GB iPhone ?
iPhone3.0
Jul 6, 2007
I was wondering, how many .mp3 files can I put into an 8GB iPhone? I'm guessing it depends upon how it was converted, but if you could give me ballpark figures, that would be great.
Sep 21, 2007
How many .mp3 can I put in 8GB iPhone ?
If you have a mac at home you can install the iPodage widget it does what you ask and more. I cut and paste the description from Apple.com, as well as the link. It's pretty cool.
About iPodage
A simple widget that tells you how many songs really fit into your iPod or iPhone. You can choose the average song length and the size of your iPod’s heart and it will calculate the possible amount. That’s not enough though! iPodage displays the ‘real’ disk space, lets you select your iPod model and remembers everything!
http://www.apple.com/downloads/dashboard/music/ipodage.html
hope this helps. :)
Sep 21, 2007
It does not hold X number of songs. It holds 8GB worth of songs.
It does hold X amount of songs if based on certain criteria.
say an 8GB iPhone can hold 350 Bohemian Rhapsody's
or 25 American Pie's
Refering to size in song terms is easier and less abstract for those who have trouble wrapping their heads around 8 GB.
I use to refer to time in Flinstone's episodes when I was a kid.
But technically you are correct an 8 GB iPhone holds 8 GB's of music......
Aug 30, 2007
Bothell, WA
Since we are being so technical the 8GB iPhone really only holds 7.27GB of music, pictures, video....
Sep 21, 2007
yep, the rest is osx. that's kind of a lot. they should really make the flash memory 8. whatever it takes to make the actual storage 8 GB
x999x
Aug 6, 2007
1,656
Enough about this on-topic riff raff, I want to know how you tell time in Flintstone episodes.
