How often do you use Siri?
Maggot
Aug 29, 2012
I wanted to take an informal survey regarding members and their Siri usage. How often do you use Siri? When and why do you find yourself using the feature?
Prozium12
Jan 22, 2012
352
35
Uk,Manchester
I find is I use an American accent it works but I'm not that good at one, but in the uk it's pointless half the time..plus doesn't it use up battery if it's on?
Sent from my iPad2 using iCafe app
coop1701
Jun 30, 2007
899
114
43
I use mine a lot. mainly in the car. But since it only works when invoked, it doesn't use any power just being on.
Maggot
Aug 29, 2012
If you press the middle button twice on phone you can cancel the program's that are tubbing in background and that saves battery life
Hinezy
May 24, 2008
533
56
Mt.Carmel, PA
I remember reading that Siri does use battery if you have the "raise to speak" feature on in settings which is on by default. I never really used the raise to speak option so I turned it off.
Sent from my 32Gb iPhone 4S using iCafe app
