how the heck is this going to work?
lennyboss
Jun 13, 2007
17
if Apple plans on selling the phones at their stores and then having you call AT&T when you get home to activate it, how are they going to verify your credit? what if you buy the phone, take it home, and then get denied service because of bad credit? are you stuck with a useless chunk of metal and scratch resistant glass?
soloudinhere
Jun 18, 2007
157
If you are concerned that your credit won't pass muster, you should go to a corporate AT&T store and have them run your credit.
I wouldn't run out and buy something this expensive if you're worried your credit won't be good enough to get a contract.
emerrill
Jun 14, 2007
126
And you do have time to return it if you don't.
But yes, if you are worried about it, I would go to AT&T instead of an Apple Store.
