How to add a movie you currently own to iPad 2?
MNJON
Nov 21, 2007
164
9
Minnesota
Is there an easy way to take a DVD Movie you own at home and put it on your iPad?
If YES, how?
Thanks!
MuddyPaws
Oct 3, 2009
986
31
Use handbrake to rip it, add to iTunes, then sync.
Doesn't work with all DVD's though.
MNJON
Nov 21, 2007
164
9
Minnesota
I tried this with 3 DVD's and it didn't work with any of them.
Any other "better" programs for this?
Handbrake is the most popular. Are you using Windows or a Mac? Can you explain the problems you experienced?
MNJON
Nov 21, 2007
164
9
Minnesota
I'm using Windows. When I choose the source, it tries reading (did it to all 3 DVD's, Patriot, Bolt and Spies Like Us) and it takes several minutes then in the activities section, it shows error messages and says something like Handbrake has exited, or something like that.
Bryman
May 30, 2009
224
colorado
Google slysoft......download anydvd,and clonedvd mobile from slysoft. They are free to try for 30 days I believe...... I use them for all my movies and it works flawlessly every time.
Lon
Jun 5, 2010
2,946
132
Alaska
DVD Shrink is another highly respected DVD ripper. It is free and worked for me when Handbrake would not. You may still need Handbreak to convert the format.
verbalj
Jan 12, 2010
390
NYC
It might be because of the copy protection on the DVDs. As someone else said, Slysoft's programs are great. In conjunction with Handbrake, it'll do what you want. There's also DVDFab (the free version).
All should help you accomplish putting DVDs onto the iPad.
