how to change AT&T
otto76
Feb 28, 2008
how do you change AT&T to say your name in the top left corner of your phone?
jptolife
Jul 15, 2007
645
New York City
If your phone is jailbroken just look up the app "make it mine" or "MIM" that'll do it for you.
Ohmster
Jan 26, 2008
533
21
SoCal
I tried MIM and all it did was launch and exit. Do you need to restart the phone first? Ditto with Banner from the same developer I believe.
depthnerd
Feb 16, 2008
1,280
I used Status Style, but it reset my Springboard arrangement afterwards.
burniksapwet
Jul 5, 2007
553
I also have MIM but I was wondering whats the difference between that and Status Style. The reason I ask is because I don't have that in my installer and if it workds better than MIM then I will add the source where that app is located. Thanks.
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
What method did you use to install MIM onto your phone? If through Installer the permissions should be auto set for you but if you copied it manually onto the phone you may need to change the permissions to the executible file.
Ohmster
Jan 26, 2008
533
21
SoCal
Thanks, it was via Installer. A reset/restart took care of it. It was one of the first things I installed without understanding some of the nuances of installing apps.
oriolesfan23
Jun 29, 2007
303
Virginia
When I had my iPhone 2G, I changed the "AT&T" in the top left corner to say "CAPS". When I got my iPhone 3G, it still said "CAPS" in the top left corner instead of "AT&T". It's still the same way with my iPhone 4. Is there anyway I can change it back to AT&T?
Saints
Jul 24, 2009
59
New Orleans
I had my JB 3gs and restored from backup with my new iPhone 4 and it kept the MIM setting. To change it I had to restore as new for it to say AT&T again. Hope that helps for you.
oriolesfan23
Jun 29, 2007
303
Virginia
That would work, but I need to restore from backup, otherwise I'll lose all my old stuff.
Saints
Jul 24, 2009
59
New Orleans
Nah I thought the same thing, but I didn't lose anything. The only thing that sucked was I had organized all of my apps in folders so I have to do it all again, but i never lost any contacts, apps, etc...
